I recently purchased the SR-71 from SimMarket, once installed I then do what I always do with a new aircraft and that is enable P3D's content logging to see what turns up.
The content logging tends to show how well an aircraft has been built and the quaility of the resultant testing prior to release.
Unfortunatelly with the SR-71 the log quickly fills with tons of repeating errors (quite similar to a Carenado plane for instance).
Any chance of getting these resolved ? a lot look to be easily resolved in the xml gauges, however the missing componets and reported model issues would be a little more involved since model editing would be required.
There seem to be a lot of general syntax errors as well as missing variables, textures and fx files.
I've listed some of them below, however all it takes to generate the list is to enable Content Logging in the P3D settings and make a test flight while enabling functions, switches etc.
Anyway, hope to hear some postive news.
Cheers
PS. I've experimented with fixing some items myself, however not being a dev crew member means mostly I'm just guessing as to logic and needed items.
error=Gauge/Script Error
Type: Gauge
Error: Undefined Simulation Variable: "General eng2generator switch".
Type: Gauge
Error: Invalid variable name: "AP_HEADING_OFF"
Type: Animation Script
Name: Lockheed SR-71A 17976-modern
Error: Invalid variable name: "AutorefuelTargetDist"
Type: Visibility Script
Error: Need units for (A:GENERAL ENG COMBUSTION:1)
Error: Need units for (A:GENERAL ENG COMBUSTION:2)
error=Gauge file not found: Glowingheat_SR-71!fuel_transfer_aft
error=Gauge file not found: Glowingheat_SR-71!NWS
error=Gauge file not found: Glowingheat_SR-71!NWS_controller
error=Texture DRAGCHUTE_SPEC.BMP failed to load (FE_REQUEST_STATUS==13)
error=Texture MIDDLE SECTION_T.BMP failed to load (FE_REQUEST_STATUS==13)
error=Texture VC_GAUGES_LAMPS.BMP failed to load (FE_REQUEST_STATUS==13)
error=Texture B58VC1A.BMP failed to load (FE_REQUEST_STATUS==13)
error=Texture VC_GAUGES_8.BMP failed to load (FE_REQUEST_STATUS==13)
error=Failed to load visual effect "fx_none"
error=Failed to load visual effect "fx_Glowingheat_A12_contrail"
error=file "bmgwarn(.wav|.ogg)" not found
error=file "sr71 afterburner1(.wav|.ogg)" not found
error=Key values exist outside of a section:
Key:Copyright 2006 Christoffer Petersen
Key:www.turbinesoundstudios.com
There are a very large number of these repeating types of error messages in both gauges and models
Error: Invalid script (command not found - perhaps a space is missing or there's an extra space?): ";" in: ;
Type: Gauge
(A:FUEL SELECTED TRANSFER MODE,enum) 0 == ;
if{ (>K:SET_FUEL_TRANSFER_FORWARD) }
els{ 0
Also has a lot of these types as well in gauges.
Error: Invalid script (no command is more than 4 characters): "SR-71"
Error: Invalid script (command not found - perhaps a space is missing or there's an extra space?): "B-58" in: B-58
Error: Invalid script (command not found - perhaps a space is missing or there's an extra space?): "A-12" in: A-12
I do otherwise like the plane itself.
