Just wanted to say that I really appreciate your efforts in bringing the A-12 into FSX.
I've done my first few flights in it and I'm very happy with its handling and think you've done a really good job with this simulation.
I've integrated a basic tacpack setup into mine using some existing freeware and payware tacpack items from other aircraft. I put a RWR where the periscope viewer is and tried it out overflying sam sites at 85K ft and M3.2. So far its been immune to missile hits!
Keep up the good work!
Ian.
First few flights
Re: First few flights
Sounds like you're having a blast!
Thank you for your kind comments. I did include an ECM on lamp and switch (on the right console) which if combined with tacpack could be used to activate the VRS tacpack ecm system, however you'd need to create the xml gauge yourself in order to arm it as I'm unfamiliar with Tacpack. Details of the L:VAR to trigger the 'ECM on' lamp are in the pdf manual in the simobjects/airplanes/Glowingheat A-12 Cygnus folder.
