A-12 Cygnus running list of items for V1.1 update
The forum for the forthcoming Lockheed A-12, Mach 3+ father of the SR-71, YF-12, M-21/D-21.
Post by DBushell » Sat Jul 08, 2017 10:43 am
To keep everyone up-to-date and to prevent multiple people posting the same bugs/feature requests, I have listed below the items being fixed/included as part of the update that will be released shortly.
1. Right FWD Bypass door needle, wasn't animating - fixed
2. Fuel tank popup not allowing use of each tank individually, and some tanks did not have selector switches - fixed
3. CG with full tanks not matching the included manual - no fix necessary - typo in the manual - CoG for take-off should be above 25% MAC.
4. Adjustment of spoiler drag to 400 to increase landing roll - fixed
5. Avionics switch in VC - will not make it into this update, would require re-coding of all gauges.
6. Cannot install to more than one location - a problem if you have FSX and P3D - installer fixed
7. M-12/D-21 mothership/drone combo - Done
8. Throttle quadrant - Done
9. Adjustment of reflection mapping from 50 to 1 for better adjustment - Done
10. Cabin pressurisation - schedule should reflect 26,000 feet - fixed
11. Cockpit Gauge map adjustments - Done
12. Interior Canopy glass now has a very subtle reflection of the pilots helmet - Done
Correct as at 3rd September.
I will update this as I go along.
