A-12 VC panel disappearing
Have a technical question about the Lockheed A-12? Ask here!
Re: A-12 VC panel disappearing
Post by DBushell » Sun Sep 10, 2017 6:00 pm
No problem, I'm fairly sure that this will fix it, but you never know!
Bizarre how the exterior mdl can cause the interior mdl to disappear!
lmeirose
Post by lmeirose » Sun Sep 10, 2017 9:49 pm
Definitely!! Who knew?? Okay...so I just tested the aircraft with the modified .mdl files you sent me. No problems at all!! I did a 2000+ NM flight from Beale AFB to Macdill AFB (near where I live in Tampa Bay, FL) with Det. 06924 (including in the conditions from Hurricane Irma on the final approach into MacDill - which provided a perfect opportunity to experience the VC rain effects!!). Everything worked perfectly. Your hypothesis was spot-on! Thanks again for your help and for looking into this so quickly. I really appreciate it. Again, excellent work on the aircraft!!
-Leo
Post by DBushell » Mon Sep 11, 2017 1:06 pm
Great news, please note that the updated V1.1 installer is now available at:
PC Aviator
Simmarket
FS Pilotshop
waiting on Justflight.
gorma
Post by gorma » Wed Sep 13, 2017 6:36 pm
Hi, David!
I swapped out the two files and everything works just perfect!
Thanks a bunsh!
Gorm
gorma
Post by gorma » Wed Sep 13, 2017 6:48 pm
Oops!... Didn't see the last page there...
Thanks again for the quick fix!
Gorm
Post by DBushell » Fri Sep 15, 2017 12:25 pm
No problem, glad it works for you!
