Starting cart and stairs are disappeared
Posted: Fri Mar 27, 2020 10:44 pm
Hi this is my first topic, and this is my problem...
I recently formatted my pc and I installed again flight simulator x steam edition, so after I installed again also the A-12 but the two starter cart and the stairs are disappeared.....
I don't know what happened...sorry...I downloaded the file from the store without the antivirus activated and I installed the file also without the antivirus activated and I installed the file like admin , but someting is wrong. The airplane in the cold and dark configuration is ok with the reds cover and ready to fly it works great. Aniway if you have a solution good otherwise it's fine.... this is the first issue that I had...You guys made one of the best plane that I ever seen in my life seems real everytings seems real.... when I watch the videos on you tube and I hear people like Frank Murray talking, I immediately fly your plane....when is possible have a conversion of all the others plane for FSX SE ????? T hanks
