A-12 Cygnus Master Caution issue
Posted: Mon Feb 08, 2021 12:02 am
Hi all,
I've got an issue with my Cygnus (used with FSX-SE): before takeoff, setting pitot heat ON will shut off the master caution light (and that's OK, I suppose, because pitot heat must be set to OFF above 60.000 feet), but immediately afer takeoff, the light turns on again with no warning message in the annunciator panel and, apparently, I've found no way to shut it down.
Is it normal? Am I doing something wrong? Any suggestions?
Thanks so much in advance for any advice,
Federico alias TMH
Federico alias TMH
