this is my first camera edit, found a vid on youtube...
copied the wing views from the default 737 and edited XYZ to get the camera as close as I could to the first station behind the pilot.
copy these and add to the camera def section of the B-58 aircaft.cfg...(meant to be added to an unedited cameradefinition section of the .cfg or you will need to change the 7 and 8 to the next numbers in order...same as editing the livery section.)
**** this \/ number****
[CameraDefinition.7]
Title = "Right Side Window"
Guid = {54F54B8A-3EC2-2D4E-8D10-B8F9D0F16ACC}
Description = View of the right wing from the cabin
Origin = Center
SnapPbhAdjust = Swivel
SnapPbhReturn = FALSE
PanPbhAdjust = Swivel
PanPbhReturn = FALSE
Track = None
ShowAxis = FALSE
AllowZoom = TRUE
InitialZoom = 0.8
ShowWeather = Yes
InitialXyz = 0.5, 1.0, 8.2
InitialPbh = 0, 0, 130
XyzAdjust = TRUE
Category=Aircraft
MomentumEffect=TRUE
ClipMode=Minimum
[CameraDefinition.8]
Title = "Left Side Window"
Guid = {0ae3f864-da10-4e5a-977c-b9bba47d6f7a}
Description = View of the left wing from the cabin
Origin = Center
Track = None
ShowAxis = FALSE
AllowZoom = TRUE
InitialZoom = 0.8
ShowWeather = Yes
InitialXyz = -0.5, 1.0, 8.2
InitialPbh = 0, 0, 230
XyzAdjust = TRUE
Category=Aircraft
MomentumEffect=TRUE
ClipMode=Minimum
always wished the other stations we're modeled but this works for me, hope you guys like if anyone can get the position better let me know
Dave
Wing views
