Hello All,
I just had a quick question for all of you. I recently downloaded V2.4 of the Glowingheat SR-71 for FSX (I'm running it on a Windows 10 operating system) and I've really been enjoying flying it. I've noticed, however, that when I perform steep climbs or turns with the aircraft, the vapor effects on the nose appear to be displaying black squares (implying they might be corrupted or missing):
Have any of you run into this issue? Is there a fix for this? Is there anything I can do on my end to resolve the problem?
Thanks very much for all of your help!!
Missing Nose Vapor Effect
Re: Missing Nose Vapor Effect
Just a quick update. I opened and viewed the SR-71's effects (.fx) files via Notepad. As it turns out, the problem was that the effect "fx_Glowingheat_SR71_vapor3.fx" effect that controls the nose vapor was attributed to the effects texture "fx_Aa-Con.bmp", which doesn't exist in the FSX "Effects" "texture" folder. The other two vapor effects are attributed to the "fx_1.bmp" (which is one of FSX's default effects textures for smoke/vapor trails, right?), and they appear to work fine; so here's what I did to fix the problem:
- I copied the "fx_1.bmp" effects texture to create a second copy of it
- Next, I renamed the "fx_1.bmp - Copy" effects texture as "fx_Aa-Con.bmp"
Problem solved!!
Problem solved!!
Glad you fixed it, I believe that fx file is included in the installer, but will need to check.
I have the same problem as the OP, but I can't get the fix that was posted above to work.
Can anyone advise?
Cheers.
Can anyone advise?
Cheers.
If you have my previous SR-71 installed copy "fx_1.bmp" from the effects/textures folder and rename it as "fx_Aa-Con.bmp"
or email me support at glowingheat.co.uk
Thanks for getting back, I tried that but it still doesn't work, the vapour still appears as in the OPs post (i.e. black)
See attached screen grab.
- Attachments
- Grab.png (244.52KiB)Viewed 10959 times
