Couple of questions:
It's mentioned on JustFlight that there are effects for fuel tank leakage. I've not seen it yet, is there anything I need to do in particular? I'm flying sub-sonic, but not topped up the tanks.
Also is there a manual on how to use XML Tools to limit the TEB counter?
Finally, if I'm taking off from a really dense population, the frame rate takes quite a hit. Other than dropping quality settings is there anything in the aircraft config that could improve things? I'm not sure what causes the frame rate to drop. Even if I fly with just the cockpit (not virtual) so nothing is showing the frame rate is still quite low compared with other aircraft from the P3D library. I guess this has something to do with the PBR? As a side note this only occurs when I'm low and slow, which isn't very often, so I'm not too worried as it's not where and how I'm supposed to be
THanks
Andy
Prepar3D V 5 (5.3.17.28160)
