Problem at start up the engines
Posted: Thu Nov 07, 2013 9:16 pm
Hello there!
I've just started to study the manual and checklist but I can't start the engines. The first problem is I don't know how I must turn on fuel suply to the engine 1 (step 7 on the checklist). I've checked the manual and almost every corner and button in the cockpit and panels but I don't find it
The second problem I suppose is consequence of the first one: after click start switch the engine's rpm stuck at 12% (maybe because it not receive fuel?). At the same time if I hover the mouse over the start switch, the tooltip is under a infinite loop changing his state from off to on.
At this stage the only way I've found to start the habu is using Ctrl+E but I would love to start this legendary bird follow the checklist.
Can you help me?
Thanks in advance
PD: BTW I'm using FSX Acceleration (spanish version).
Can you help me?
Thanks in advance
