cg MAC problem
Technical support for the FSX version. Don't forget to check the manual included in the package first before seeking advice.
dave76
cg MAC problem
Post by dave76 » Wed Mar 25, 2015 11:03 pm
hello,
i notice if i select the fwd fuel transfer in manual mode the cg shift aft and same for the opposite action according to page 25 of the manual ( select fwd shift during climb to move cg aft.......). but i read somewhere else that fwd shift should move cg fwd and aft should move cg aft ......so i am little confused....... :(
i took off with cg of 22 % and 64000 lbs of fuel i guess......what did i made wrong? ( for sure i did) :( :D
did anybody else experience the same? :D :D
many thanks for your reply,
david
lmeirose
Re: cg MAC problem
Post by lmeirose » Thu Dec 13, 2018 9:02 pm
Hi David,
Looks like we might have had a similar issue (though in my case, the problems were with the SR-71B trainer model)! Thankfully, corresponding with David Bushell and Glowingheat helped to remedy the situation. Here is the link to the original thread I posted on the Glowingheat forum. You may find this helpful:
viewtopic.php?f=6&t=439&p=1196#p1196
Best of luck!!
