Enterprise Steam Install [Closed]
Hi, I purchased the Enterprise 10 July 2015 from FSPilot Shop Order #690221. I re-downloaded the file today which on the download site states the file was last updated 22 September 2015. The file is SBD-330. Is this version compatible with FSX Steam? If not do I have to repurchase?
Re: Enterprise Steam Install
I think the file name is something assigned by FSPilotshop. The venders all have the latest release. The only change being a new installer that will make things easier and allows you to install it in FSX, FSX-SE, or P3D. If you run it you should be asked what version you want to install.
You should not need to repurchase anything unless you are upgrading from the FS9 version which is a totally different product.
When I ran the installer it didn't ask which version. It automatically installed to my directory I set up for FSX Steam which is E:FSX1/steamapps/common/FSX.
The vendors were all requested to retain the original versions for people who wanted re-downloads. So you should have the version you originally purchased.
So, do I have to buy it again to get the FSX Steam install version?
No the version you have is exactly the same version as the Steam version in the new installer and as you say it auto installed to your installation of FSX Steam. Only the installer has been reworked to offer the option of installing to FSX ,FSX-SE or P3D v1&2
