Post
by dickb » Thu Feb 11, 2016 10:59 am
Well, it is a rather old card now (GTX580), and I'm sure it is working quite hard, but I'm not sure that is the problem. When I say I have all settings maxed out, that's a bit misleading. I do run the scenery and autogen settings at max, but on the other hand I don't fly complex a/c, I have all roads, railways etc disabled in my scenery (gives a more WWII look), and all regular road, GA and airline traffic is disabled. The only traffic is my own WW2 AI, which is relatively light in FSX terms. I do use complex clouds, but basically everything is smooth and I have no scenery problems beyond the usual autogen popping. And I don't really want to compromise my overall experience to accommodate specific scenery !
All that said, I did do some testing along the lines that you suggest. I cranked the autogen settings all the way down. And far from improving the situation, it seemed to make things worse. With the setting at Normal or above, the Halifaxes break up as I approach as in the pix, but then display correctly when I get closer. With the autogen setting lower than Normal, they appear always incomplete and never display completely at all ! I also notice other scenery objects (e.g. bomb trailer and tractor) breaking up and displaying incomplete at lower autogen settings.
As mentioned above, the AI models seem to be fine. The static a/c at Silloth are fine. And I also have your Dambusters Scampton scenery with static Lancasters that seem OK too. It seems to be just the Halifaxes that present the problem.
EDIT: Forgot to include my order details: FlightSimStore #460312
