Hi guys
I just installed RAF Binbrook for FSX (I was stationed there from 84-87) and overall I'm delighted with it, the AI works a treat and it looks pretty good. There is one small issue, I have a grass strip across 03 just after the PAPIs. I don't have any additional UK mesh installed, it's plain FSX SP2 scenery so it isn't conflicting with anything.
Is there anything that can be done to remove it ?
Thanks
Sampa
Binbrook runway grass [Resolved]
Re: Binbrook runway grass
Installed Binbrook into FSX - Acceleration which is basically FSX SP2 with extra aircraft and aircraft carrier support.
I'm not seeing any green area across any runways at Binbrook. I don't have any extra scenery or mesh installed and
the sliders were all moved to the far right in Options/Scenery. We use a flatten file so there should be no issues with
the runways over the grass layer. Can you provide a screenshot so we can view it at the same angle?.
OK, was that the power of positive thinking? I took this screenshot when it happened, but when I went to get a shot from the same angle as yours a few minutes ago the grass was gone !! Even at ground level it no longer appears, so everything is as it should be.
Thanks for the quick response, now it's time to go flying
I looked from the same angle as your image angle and can't get it to happen either.
Not sure what would have caused it in the first place except that there is a crossing runway in that area.
It isn't showing in your image either so that might be what is going on. Perhaps it hadn't loaded yet?
In any case, good to hear it has stopped for you.
