CVN-65 install question [Resolved]
Re: CVN-65 install question
Post by fsafranek » Sun Jun 12, 2016 3:31 pm
I run FS9 (for testing), FSX, FSX-SE, Prepar3D v1, and Prepar3D v3 all on drive E: so that should not be an issue.
Go into Prepar3D v3 and and select "Scenario -> Save". At the top of the window will be a field to type in a file name and below
that will be the location they are going to save the file. In the attached image I have outlined that location with a red box.
In my case that is on drive E:, but it may be different for you.
That location where you need to tell the installer where you want the Saved Flight files located when you run the Flights Installer.
After successfully doing that you will have the CVN-65 flights listed below to select from.
