Team SDB Scenery Activation
Post by mickeyd » Sun May 20, 2012 12:02 pm
Scenery "Activation" Instructions for Team SDB Scenery:-
Click to the "Settings" tab in the Start Page of FS.
Click on the "Scenery Library" tab under "Scenery"
Click on the "Add Area" tab.
Use the Browser window which comes up to locate \Addon Scenery\[Scenery Name]
Click on "OK" tab
Click on "OK" tab at the bottom of "Settings-Scenery Library" page.
Restart FS to finish the activation process.
NOTE:
Set scenery density to at least 'dense' or 'very dense' to get static aircraft (if inc.) to appear.
Some scenery objects may also be set to a high density in order to improve frame rates on lower specification
computers.
Set traffic density if applicable to 100% for full AI operation.The AI traffic percentage may also be lowered
to increase framerates. Minimum is 10%
Uninstall / De-activation proceedure:- If you run the Uninstaller program you will need to remove all
references from the "Scenery Library" manually. Just reverse the above steps.
Guaranteed DX9 compatible but NOT guaranteed compatible with DX10 Preview (Disable it).
How to Add Addon Scenery in Windows 7,8 and 10
There is a bug with Windows(7,8,10) Explorer and Flight Simulator X because of its difference to Vista and XP.
To add addon scenery in FSX/Windows 7,8 and 10 follow these steps.
1. Go to the "Scenery Library" in the "Settings" Menu
2. Browse to the folder you want to add and hit 'OK'
3. The addon scenery that you have selected will not be added,
instead it will advance inside the directory.
To add the scenery LEFT click on any blank space inside the folder, and the windows should close.
You should now see the addon scenery selected in the scenery library!
