USS Robison
Butch
USS Robison
Post by Butch » Sat Feb 08, 2020 1:07 pm
There's a DDG Robison supplied with the Team SDB Enterprise, Is there a fix for the misaligned exhaust smoke for the USS Robison DDG-12?
Exhaust is high and little off center of stacks. (P3D V3.4) Perhaps an effect file issue.
DDG_smoke_d17A.fx
DDG_smoke_d17B.fx
mickeyd
Re: USS Robison
Post by mickeyd » Sat Feb 08, 2020 9:47 pm
So we can answer your query please quote the store and order number.
Butch
Re: USS Robison
Post by Butch » Sun Feb 09, 2020 12:43 am
SimShack.net
Order Number: xxxxxx
Is that sufficient?
I ask about this at SIM OUTHOUSE see response # 24. I might of been able to fix it but need P3D SDK installed
before using MCX.
http://www.sim-outhouse.com/sohforums/s ... ise-Update
Re: USS Robison
Post by fsafranek » Mon Feb 10, 2020 12:36 am
I've been away all weekend. I'll install the original Enterprise into P3Dv3 and have a look. I'm running v3.4.23.20420.
Re: USS Robison
Post by fsafranek » Mon Feb 10, 2020 3:03 am
Yep, it's an issue with P3Dv4 as well. FSX and FSX-SE using the exact same files are okay. We'll get it fixed.
Butch
Re: USS Robison
Post by Butch » Mon Feb 10, 2020 12:20 pm
Thanks Frank for looking into this.
I got your PM over at outhouse. I also sent you a reply PM over there as well.
When that issues is fixed, how will that be dispatched, separate file or new installer or....?????
"Butch" aka Grayeagle.....(SOH)
Butch
Re: USS Robison
Post by Butch » Mon Feb 10, 2020 9:56 pm
Frank,
I just read your PM over at SOH about installer. It sounds like both FSX and P3d were combined into one installer but what was confusing was that the installer
title says fsx acell. I did a manual install to P3D V3.4 -
Now it is my understanding that the mismatched smoke effect is still a WIP for correction as it sounds like you noted it in P3D.
Not sure about that RFN gauge you mentioned over at SOH (what the issue is/was) but discounting that, the issue with the smoke effect
is something that you are still trying to remedy.... at least I hope so... :D
Butch
Re: USS Robison
Post by fsafranek » Wed Feb 12, 2020 1:29 am
Prepar3D seems to handle offset values in effects files differently than FSX. That is why the smoke was out of position.
We have edited the USS Robison mdl file to correct the issue and use a single effects file with no offset.
Download the file linked below and view the Readme.txt file.
P3D_Robison_Smoke_Correction.zip
New Smoke in P3D.jpg (56.48KiB)Viewed 108844 times
Butch
Re: USS Robison
Post by Butch » Wed Feb 12, 2020 7:16 pm
It works now and the issue is resolved. :D
Thank you for fixing this.
udidwht
Re: USS Robison
Post by udidwht » Thu May 28, 2020 2:14 am
Latest v3 is...
3.4.22.19868
Win10Pro22H2-19045.2486/i7-3770K/32GBG-SkillDDR3/RTX2070OC/1TBCrucialMX500SSD/(x3)1TBRAWMushkinSSDs/LGBlueRayDL/CorsairRM750PSU/RosewillMidTowerChallenger/X56HOTAS/ThermaltakeECommanderCombo/InateckKU5211USB3.2/OculusQuest2
