22.11.2020
Order Number: 70368
Simshack
FSX:SE
Greetings!
Today I bought the Loring AFB addon.
1) When I compare it to the pictures in the manual, I see the airport aerea should have many trees. It has none. I have tried reinstalling to no effect.
2) The manual states that "The static aircraft...are scaleable to suit most systems". How does one remove the static aircraft? Which bgl is to be removed?
Please advise.
All else works fine - best regards!
SDB Loring AFB has no trees
Re: SDB Loring AFB has no trees
Hi. Thank you for the purchase. This was an interesting base to build.
1) I just reinstalled it into FSX-SE and have plenty of trees. I can effect the trees via Autogen Density.
Go to Options->Settings->Display->Scenery->Scenery Objects->Autogen Density.
I tend to have it set at "Very Dense"
If I go with the minimum setting for Autogen Density I can remove all trees. So have a look at that setting.
2) I can reduce the number of static aircraft by adjusting Scenery Complexity.
Go to Options->Settings->Display->Scenery->Scenery Objects->Scenery Complexity.
I can reduce the number of parked static aircraft using this but I also lose some buildings in the process.
Hope this helps.
Hope this helps.
