Hello,
Earlier I asked David if his B-58 fs9 will work in fsx. I asked him to about the Bunker Hill scenery for fs9. I found BH scenery for fs9 in the freeware of alphasim at virtavia.
So I tried this scenery in FSX. Well the BH air base and its components seem to be ok. Delivered is also an B-58 AI. But this airplane is bouncing up and down with a lot of smoke all over the place! Some are even burried in the ground in the end and will resurrect later!
I learned that the model was made by David Bushell and that Frank Safranek was involved too.
So my simple questions, although I realize that this is maybe not supported, how to change the bad behaviour of this AI B-58 under fsx.
I should be very obliged if you will give me an answer.
Thanks and best regards,
Koos van Menen
The Netherlands
AI Bouncing in FSX [Closed]
Re: AI Bouncing in FSX
The FS9 version of Bunker Hill which Virtavia have on their freeware site contains B-58s that will only work in FS9. In fact Virtavia/Alphasim were not authorised to release it and several others. Thank you for making us aware of it.
All but two of the sceneries offered are very old Team SDB sceneries. I shall be contacting them to remove it and several others.
If you want a B-58 AI that WILL work in FSX Acceleration you will need to purchase US Airfields Vol 2 FSX which contains them.
