Hello,
As I would like to have my own stastic objects in tead of the Lightnings, I disabled the file STATIC PLANES.BGL. The Lightnings indeed disappeared, but instead there were some hundred or so white vans.
Now: What file contains these vans or their addresses? Can I remove that without damaging other things?
reg.,
Piet de Geus
Netherlands
RAF Leconfield scenery objects [Resolved]
Re: RAF Leconfield scenery objects
I'm afraid it's nothing to do with our scenery. It's something else on your system. Possibly your Treescape addon as I also see trees behind them.
See the info below to remove them supplied by Dave Booker (DaveB) I think you will find these .agn files in a texture folder (Treescape folder ?):
For reference, these are the Treescape AGN's that cause the woodland scene at Leconfield:
010331133120223An.agn
010331133122001An.agn
010331133122003An.agn
010331133120232An.agn
010331133122010An.agn *********
010331133122012An.agn
Many thanks for that Dave.
010331133120233An.agn
010331133122011An.agn
010331133122013An.agn
The one marked "**********" is the centre of the field.
Should any other user with GenX and Treescapes have the issue, you can pass this info on. There is no need for the UK2K Vol3 ground file if they rename the files above
