CTD in P3D V4, starts with Nose tilted up in the air?
Have a technical question about the Lockheed A-12? Ask here!
RobAinscough
Post by RobAinscough » Mon Jun 26, 2017 9:35 pm
Hi folks,
Seems to be a slight problem with the A-12 in P3D V4, after about 5 minutes the aircraft will CTD.
Also noted that when I start at any airport, the front nose of the aircraft is off the ground tilted up, as if the flight model CG is wrong and/or all the fuel in the rear ??
Thoughts?
Cheers, Rob.
Re: CTD in P3D V4, starts with Nose tilted up in the air?
Post by DBushell » Tue Jun 27, 2017 8:26 am
Hi Rob,
That's strange you get a CTD, I've not heard of any others so far. If it keeps happening, let me know your system specs, OS version and what your graphics settings are and what you're currently doing in the simulator eg how high fast etc.
I would also suggest creating a new flight, because if you use the default flight it will start tilted upwards due to the previously loaded models settings. The CG is quite specific, so create a new flight and see how that goes.
Not sure if it might make a difference, but I see there is a hotfix for Prepar4d V4
http://www.prepar3d.com/news/2017/06/114375/
Worth a try as it fixes quite a lot of items including some memory leaks.
Kind regards,
david1952
Post by david1952 » Thu Jul 04, 2019 11:49 am
At Eglin code KVPS a default airport it is tilted...
On other add-on airports it looks fine.
Regard, David
Post by DBushell » Tue Jul 09, 2019 7:16 pm
Hi David1952,
Make sure that the aircraft has 100% fuel, or at least balanced tanks. If you're loading a saved flight, it often loads the saved fuel state of the previous aircraft, which in the case of the A-12 may cause it to tilt upwards, because too much fuel is at the aft end.
