Floating Trees
mikec
Floating Trees
Post by mikec » Mon Nov 04, 2019 6:15 pm
I have a number of SDB products, all installed in P3Dv3. They all look great except for one problem - trees appear to floating about 2mtrs off the ground (I am talking about trees on the airfield not autogen).
The airfields where this is most noticeable are Binbrook, Cottesmore, Finningley, Leconfield and West Raynham. Non-SDB addons are ok. Colerne appears to be ok but that might be because it is FSX copied into P3Dv3.
Does anyone have any thoughts about this?
Mike
Re: Floating Trees
Post by mickeyd » Sat Nov 09, 2019 7:19 pm
Do you have OrbX or Generation X installed. If so disable the mesh. SDB airfields are designed to work in "vanilla" FSX/P3D + and use the default elevation. OrbX amd Horizon feel (wrongly) it needs correcting.
Edit: Just checked all those in FSX ( P3D v3 scenery is 32 bit FSX format) and all trees are firmly rooted even with GenerationX mesh activated so you need to dig deeper into your sim for the problem I'm afraid.
mikec
Re: Floating Trees
Post by mikec » Sun Nov 10, 2019 11:03 am
Thanks for checking. I do have Orbx but it is disabled and the rest of my p3dv3 installation is very vanilla (I think).
I will obviously have to check further.
MikeC
