SR-71 FSX 2022 Edition Changes
The place to discuss anything not relating to technical support.
af120835
Re: SR-71 FSX 2022 Edition Changes
Post by af120835 » Thu Mar 30, 2023 8:51 pm
DBushell wrote:
Thu Feb 02, 2023 1:44 pm
Ah, forgot about that!
Shame i couldn't get that to work in P3D 5.3 - it used to work in earlier versions. Glad you sorted it.
I've been dabbling with the 2022 model and the previous version (2011? FSX) both in P3D V5.3.
The old version does indeed work: the radar panels and refueling panel comes up fine. If I chase a selected aircraft and have auto refuel on the tanks top up to 100%.
I've been having a play with the 2022 panel config by adding the info provided by renniks. The refuelling panel comes up fine, and but oddly the radar panel comes up as what appears to be the underlay of the look down part of the old (pre-2022) RSO view window.
I've tried adding the Glowingheat bit he mentioned in the aircraft.cfg file but that doesn't seem to make any difference.
So I think it's capable of refuelling in P3D V5.... things just need tweaking.....I'll play for a bit more... I think I'll attempt to get it working in the FSX-2022 version first and go from there.
Update 01/04/2023:
(Not an April fool).
So yesterday I installed the 2022 Version into FSX-SE and got the refuelling panel and radar panel working in that.
I copied that into P3DV5.3 folder and now that works too in P3D: full radar and panel and it refuels too.
But if I replicate what I did in the FSX version into the panel and aircraft files into the P3D version, I can still only get the refuel panel up and the other panel displays a downward view. The refuel function works if you get close, but the radar would still be a nicety to have.
This is the pre-2022 version
Just refueled.jpg (222.36KiB)Viewed 5678 times
af120835
Post by af120835 » Sun Apr 02, 2023 8:55 am
Update 2/4/2023:
In the end I gave up trying to have a separate window for the radar and refuel in the P3DV5 version, so I combined them into one as I'd used them both anyway so saves clicking multiple times:
All changes to be made with P3D closed.... otherwise nasty things happen or you won't see changes etc etc....
Updated the panel.cfg to read the following and add a [Window06] at the appropriate point in the file:
[Window Titles]
Window00=Radio Stack Panel
Window01=Fuel Panel
Window02=ECU and Electric Panel
Window03=GPS
Window04=AP window
Window05=AGE
Window06=Refuel
[Window06]
size_mm=250,550
windowsize_ratio=0.2
position=1
BACKGROUND_COLOR=0,0,0
VISIBLE=0
ident=19998
gauge01=Glowingheat_SR-71!AUTOREFUELG,0,0,250,250
gauge02=Glowingheat_SR-71!RADAR1G,0,250,250,300
And as stated earlier in this thread, in aircraft.cfg every line like this:
title=Lockheed SR-71A 17958
Needs changing to
title=Glowingheat Lockheed SR-71A 17958
I literally don't know why it won't accept a Window07. I've even tried creating a window 7 which was an exact duplicate of Window06, save for the ident, as I knew that window worked. but it wasn't having it. It still showed a downward view. That'll do for now.
BTW... don't forget to have other air traffic turned on otherwise you won't see any planes.
