BAC TSR-2 on RAAF Scherger
Jorgen
Post by Jorgen » Thu Jun 29, 2023 4:24 pm
I just purchased this scenery, and it shows up just fine in P3D v. 5.4.
The only problem I have is the TSR-2. It shows, but wings and fuselage only. Fin, tailplane and undercarriage are missing. I will try to attach a screenshot.
Screenshot (48).jpg (248.19KiB)Viewed 7221 times
Jorgen
Re: BAC TSR-2 on RAAF Scherger
Post by fsafranek » Fri Jun 30, 2023 12:39 am
Hi.
Where did you buy it from?
I want to see what they show as compatible sims.
Jorgen
Post by Jorgen » Fri Jun 30, 2023 5:34 am
I bought it from Simshack. They seems to offer two versions, I opted for the "most recent" or words to that effect.
Jorgen
Post by fsafranek » Fri Jun 30, 2023 2:36 pm
I only see one version of our RAAF Scherger listed there:
https://www.simshack.net/products/raaf- ... y-fsx-1346
That page makes no mention of compatibility with any version of Prepar3D at all.
The problem looks to be a display issue with the AI TSR2.
Does it occur at all times or only when they are in motion/active?
I see red text about that one, that's why I ask.
Jorgen
Post by Jorgen » Fri Jun 30, 2023 4:43 pm
Interesting... the red text appears above all AI aircraft traffic in my installation, and it also used to do that with earlier version of P3D, and with FSX Acceleration and FSX:SE. So that is normal.
And the issue occurs all the time with the TSR-2, but as far as I can see all other AI aircraft display OK, which shouldn't be a problem with a nVidia RTX 3060.
Since the aircraft (at least partly) shows, it must be at least a FSX or a P3D model, if it was the FS9 model it would not show at all. But I have never had an AI aircraft show only partly.
Maybe I should purchase RAF Wyton and see if that TSR-2 shows up properly, and if it does, just grab that model for the RAAF AI traffic...
Jorgen
Post by fsafranek » Sat Jul 01, 2023 2:16 am
Are you putting RAAF Scherger into the root of P3D or are you putting it into the "\Documents\Prepar3D v5 Add-ons" folder.
If the latter please paste the "addon.xml" file contents below. I'll give it a try on my system.
Jorgen
Post by Jorgen » Sat Jul 01, 2023 2:35 pm
It is in the Add-ons folder, and here's the xml file:
SimBase.Document Type="AddOnXml" version="4,0" id="add-on">
<AddOn.Name>YBSG RAAF Scherger</AddOn.Name>
<AddOn.Description>YBSG RAAF Scherger scenery</AddOn.Description>
<AddOn.Component>
<Category>Scenery</Category>
<Path>I:\P3D V5 Scenery\Oceania\YBSG RAAF Scherger</Path>
<Name>YBSG RAAF Scherger</Name>
<Layer>850</Layer>
</AddOn.Component>
</SimBase.Document>
I should say that all my AI aircraft are not in the SimObjects\Airplanes folder, but in a dedicated AI aircraft folder, and that all my flight planes are in the scenery\world\scenery folder.
Jorgen
Jorgen
Post by Jorgen » Sun Jul 02, 2023 1:40 pm
Problem solved.
I bought the RAF Wyton scenery. The TSR-2 model there is a P3D v. 4 model from 2021, the one in the RAAF Scherger scenery a model from 2006. When I replaced the model in RAAF Scherger with the one from RAF Wyton, everything was fine, and the TSR-2 looked beautiful as it should.
Jorgen
Post by fsafranek » Sun Jul 02, 2023 2:32 pm
Glad it worked put. Sorry about extra step. Wynton's not a bad scenery on it's own. Both are "what if" types.
Problem solved.
Jorgen
Jorgen
Post by Jorgen » Sun Jul 02, 2023 3:33 pm
I like the sceneries a lot. I have some MAIW RAF base sceneries, and the SDB sceneries will probably replace some of those.
Jorgen
