B-58 Afterburner Mod
Got the FSX native B-58 Hustler? Ask questions here!
Post by fsafranek » Thu Jul 10, 2014 2:45 pm
Henk ("hschuit") Schuitemaker's has made a modification to the afterburners of the B-58.
His description:
- Below 95% rpm, the engine exhausts/burners were untextured black holes.
- Above 95% specially the inner engine burners where not visible at certain viewing angles.
He also updated the [smokesystem] and the xml controller: Before, all engines would smoke depending on engine 1 rpm. Now each engine's smoke depends on the rpm of that particular engine.
It is available from the Add-Ons Library at Sim-Outhouse.
dbhally
Re: B-58 Afterburner Mod
Post by dbhally » Sun Feb 08, 2015 1:33 am
I just added the fix and thank you, works great, nice improvements ;)
skipph1
Post by skipph1 » Tue Mar 03, 2015 9:35 pm
Seems the effect has not made it into P3D 2.5. Any chance of having a look at that mode? Thanks, Skip
Post by DBushell » Wed Mar 04, 2015 9:35 pm
Hi Skip,
Make sure that the effect .fx file and it's textures are in the P3D effects folders.
As far as I know there is no reason why they shouldn't work, although I have not tested them myself.
skipph1
Post by skipph1 » Thu Mar 05, 2015 12:36 pm
Dave, Glad someone is awake because I sure am not. That was the problem, no effects put into the effects folder for the 2.5 version. Thanks, Skip
