RAF Leconfield
leggo
RAF Leconfield
Post by leggo » Sat Mar 24, 2018 12:50 pm
hi...it is sorted..I found the conflict and everything seems ok.
Sorry to be a pain
kindest regards
ian
Re: RAF Leconfield
Post by fsafranek » Mon Mar 26, 2018 3:51 am
Hi.
Just for our own education in future cases, what was the causing the issue?
Re: RAF Leconfield
Post by fsafranek » Mon Mar 26, 2018 8:48 pm
leggo wrote:... the conflict with the Leconfield scenery was that I had installed UK 2000 VRF airfields scenery volume 1 installed which of course gave the conflict with your scenery.
Right. When used with UK 2000 you may even see two air bases overlapped. Best bet is to disable UK 2000 in Scenery Library when using our bases.
At a minimum for compatibility with all other addon scenery, UK 2000 should be pushed down in the Scenery Library to just above "Propeller Objects".
At least this way our scenery, which we only design to work with default FSX/P3D scenery/mesh, will have a chance to display correctly.
leggo
Re: RAF Leconfield
Post by leggo » Wed Mar 28, 2018 1:50 pm
HI. Many thanks for the input I will do it..
kindest regards
Ian
