hi...it is sorted..I found the conflict and everything seems ok.
Sorry to be a pain
kindest regards
ian
RAF Leconfield
Re: RAF Leconfield
Hi.
Just for our own education in future cases, what was the causing the issue?
Re: RAF Leconfield
Right. When used with UK 2000 you may even see two air bases overlapped. Best bet is to disable UK 2000 in Scenery Library when using our bases.leggo wrote:... the conflict with the Leconfield scenery was that I had installed UK 2000 VRF airfields scenery volume 1 installed which of course gave the conflict with your scenery.
At a minimum for compatibility with all other addon scenery, UK 2000 should be pushed down in the Scenery Library to just above "Propeller Objects".
At least this way our scenery, which we only design to work with default FSX/P3D scenery/mesh, will have a chance to display correctly.
Re: RAF Leconfield
HI. Many thanks for the input I will do it..
kindest regards
Ian
kindest regards
Ian
