EGUP RAF Sculthorpe in P3D v. 5
Jorgen
Post by Jorgen » Fri Oct 27, 2023 7:20 am
I bought this yesterday, and it looks like my aircraft are taxiing on a surface about 30 cm./1 ft. or so beneath the visible runway and taxiway surface. I can supply a screenshot if required.
I also bought EGXV RAF Leconfield and EGVL RAF Little Rissington, but haven't checked them out yet.
Jorgen
Jorgen
Re: EGUP RAF Sculthorpe in P3D v. 5
Post by Jorgen » Fri Oct 27, 2023 1:29 pm
On EGXV, I found almost the opposite issue - the runway and taxiways look like they are on embankments, about 6- cm./2 ft. high.
On EGVL, no issues like that, and I was able to watch 3 Bulldog T 1 (from a MAIW flight plan) taxi out and take off. On the other hand, the runway has no centerline...
Jorgen
Post by fsafranek » Sun Oct 29, 2023 7:57 pm
Can you tell us where you purchased it from?
We want to look at the product page and check something.
We can also try it here and see if we see the same thing.
Post by fsafranek » Sun Oct 29, 2023 8:56 pm
I installed all three you mentioned into P3D v5 by changing the "Prepar 3D v4" reference during install to "Prepar 3D v5".
None of our scenery products are marketed as compatible with Prepar 3D v5. But some of them do seem to work.
Here are images of the three sceneries you mentioned and judging from the tire position of the default Iris Texan II (brought to P3D v5 from v3).
Hope this helps. Nice to know we still work in the later versions of P3D. Now have to check out v6.
RAF Little Rissignton in Prepar v5
RAF Little Rissignton P3D v5.jpg (107.5KiB)Viewed 144269 times
RAF Leconfield in Prepar v5
RAF Leconfield P3D v5.jpg (117.4KiB)Viewed 144269 times
RAF Sculthorpe in Prepar v5
RAF Schulthorp P3D v5.jpg (92.82KiB)Viewed 144269 times
Jorgen
Post by Jorgen » Mon Oct 30, 2023 7:43 am
I need a small hardware modification on my system (for my own satisfaction), then I'll be porting everything to v. 6. I have every confidence that the sceneries will work there too.
But I notice that at Sculthorpe, you had the T-6 on the ramp. What does it look like on the runway threshold? I'll post a screenshot from there later.
Jorgen
Jorgen
Post by Jorgen » Tue Oct 31, 2023 11:49 am
After a small delay (real world interfering), here's a couple of pictures from RAF Sculthorpe:
First on the runway threshold:
Screenshot (54).jpg (198.3KiB)Viewed 144252 times
Then, just off the runway:
Screenshot (55).jpg (224.41KiB)Viewed 144252 times
Now, on the way to the ramp:
Screenshot (56).jpg (232.66KiB)Viewed 144252 times
Jorgen
Jorgen
Post by Jorgen » Tue Oct 31, 2023 11:50 am
And a fnial one, near the end of the ramp:
Screenshot (57).jpg (221.08KiB)Viewed 144252 times
Jorgen
Post by fsafranek » Wed Nov 01, 2023 6:20 am
Some more images at RAF Sculthorpe in P3D v5. Aircraft is sitting and taxiing without any issues.
If we ever update this for P3D v5 we'll look at why the engine grime smudges are pointing up rather than lying flat.
Sitting at end of Runway
RAF Sculthorpe in P3D v5 Runway End.jpg (95.48KiB)Viewed 144250 times
After taxiing to grass near end of runway
RAF Sculthorpe in P3D v5 Grass by Runway.jpg (88.17KiB)Viewed 144250 times
After taxiing towards parked static aircraft
RAF Sculthorpe in P3D v5 Taxiway.jpg (83.8KiB)Viewed 144250 times
Jorgen
Post by Jorgen » Wed Nov 01, 2023 8:23 am
It looks rather like some of the B-66's are doing cartridge starts!
I may, in the vague future, get Pilot's Mesh. This may (hopefully) also fix some other elevation issues I have.
Jorgen
